Highlighted
by Investigator
High Ping & Slow Speeds
Hey. I've been on EE for about a week or two, when we first got it we were getting around 20 MPBS on speedtest.net - Then we upgraded to 50 MBPS, it was 50 MPBS for few days. Now it's back down to around 20 MPBS.
It's not only that, in games I also have ping around 70-80 to servers 1 hour away from me (Oxford > London).
I've spoke to live support plenty of times, they just tell me to factory reset the hub, which I've done, and I still get these terrible speeds.
Highlighted
Re: High Ping & Slow Speeds
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
4. What does BT Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number, use the Address Checker, not the Postcode Checker.
5. What's the tracert to BBC.co.uk & to your game server?
Highlighted
by Investigator
1. Don't have that option
2. https://www.thinkbroadband.com/speedtest/1559928875299453955
3.  Not sure our phone number
4. Same as 3
5.
C:\Users\Nathan>tracert bbc.co.uk
Tracing route to bbc.co.uk [151.101.64.81]
over a maximum of 30 hops:
1 4 ms 4 ms 4 ms 192.168.1.254
2 * * * Request timed out.
3 * * * Request timed out.
4 9 ms 8 ms 8 ms 213.1.115.205
5 85 ms 39 ms 79 ms 213.1.79.54
6 11 ms 15 ms 59 ms 87.237.20.136
7 12 ms 11 ms 11 ms lag-107.ear3.London2.Level3.net [212.187.166.149]
8 13 ms 68 ms 12 ms FASTLY-INC.ear3.London2.Level3.net [212.187.192.202]
9 12 ms 72 ms 13 ms 151.101.64.81
Trace complete.
No idea how to check to game server
Highlighted
  1. Why not? What router have you? All routers have connection stats. This info is essential to discussing your line and issues.
  2. .....
  3. Look in your MyEE for your phone number in a bill or under Your Plan
Highlighted
Hi @nathan10
Your ping could be the server you are connecting to, traffic, their internet connection..etc. this is not necessarily EE line.
Are you gaming over WiFi or are you wired to your router? Equally are you speed testing over WiFi or via ethernet?
Highlighted
by Investigator
Speedtesting & Gaming via Ethernet!
