by qtflamey
High Ping While Gaming
Pinging lux.valve.net [146.66.152.2] with 32 bytes of data:
Reply from 146.66.152.2: bytes=32 time=914ms TTL=54
Reply from 146.66.152.2: bytes=32 time=1016ms TTL=54
Reply from 146.66.152.2: bytes=32 time=840ms TTL=54
Reply from 146.66.152.2: bytes=32 time=1128ms TTL=54
My ping get some ridiculous numbers at times.Im using an Ethernet cable 17mb/s EE boradband.How do i fix this
Re: High Ping While Gaming
If you would like help with your speed or connection issues, please would you carry out the steps and provide the data as requested in the Need Help with Your Home Broadband Speed or Connection? sticky. This will enable us to diagnose the problem and advise you further.
Reply from 146.66.152.2: bytes=32 time=28ms TTL=52
Reply from 146.66.152.2: bytes=32 time=29ms TTL=52
Ping statistics for 146.66.152.2:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 28ms, Maximum = 29ms, Average = 28ms
