by comprop
High Ping Issue
I have had an intermittent problem with very high ping for a long time. I have had a new router, an engineer visit (found no internal problem - but fitted new front to the phone socket jic), changed from ip to adsl all to no avail. Previous calls to ee have been helpful recognised the problem and  suggested solutions. My latest call about the problem met with a response - you have a stable connection and very high speeds and no isp will guarantee ping times.
I'm not a gamer, I don't use p2p software or have a vpn, but this ping problem can last for more than an hour at a time or 10-15 secs. I live 800m from the exchange, there are no overhead power cables , my neighbours wifi doesn't interfere.
I have done numerous tracert and send print outs of ping times.
Anyone got any ideas how to address this problem now.
Re: High Ping Issue
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
4. Post your ping to BBC.co.uk.
