by Oga
Hi, can’t connect my IMac while all other devices are connected. Any idea please
13 REPLIES 13
Re: Hi, can’t connect my IMac while all other devices are connected. Any idea pl
Good Evening @Oga
Welcome to the community.
Are you connecting to an EE Broadband router?
How many other devices do you have connected?
Leanne 🙂
Connect your iMac to what?
by Oga
Hello Leanne
Yes I am. There are about 10 other devices including Chromecast and SmartTV. Basically all others are wireless and connect ok.
@Oga : Can you see the SSID of your router in the list of networks seen by the Mac? If so, click on it & supply the WiFi password of the router.
by Oga
To wiFi (thru EE broadband) while all other wireless devices are connected
by Oga
Hello yes I can.
So what happens when you supply the WiFi password to it?
by Oga
Basically for a very short period of time it works and then connection is lost. Computer somehow freezes if I try to reconnect. After 10 minutes I can try again but impossible to connect.
Got the computer checked by Apple. Said no issue there.
Hi @Oga
Is it possible to connect your iMac to a different WiFi connection, as a test?
by Oga
Hello,
Difficult but I have changed once the EE router.
I used to be on BT and never had any issues connecting this IMac.
Have you managed to try a different WiFi connection since we spoke, @Oga?
by Oga
Hi Chris
I have stopped using a wireless computer which was sitting next to the iMac and it worked well. Will try again later. It could too many devices were connected.
With another Wi-fi connection it was the same issue.
Let us know how you get on @Oga
Leanne 🙂
