Help! New customer 0.3mbps broadband speed!
Hello,
i have just just signed up in a new house and have very very slow broadband.
router connected to open reach master socket with built in filter, no other filter.
tried resetting etc.
speed test shows 0.24Mbps down 0.48Mbps up 33ping
exchange-https://www.samknows.com/broadband/exchange/THWO
router details- time connected 00:40:28
DSL STATUS
This page shows information about your DSL connection. If you are using Fibre/Ethernet Broadband then this page is not applicable.
STATUS
Configured Current
Line Status -- UP
Link Type -- Interleaved Path
Operation Mode Automatic G.992.5 (ADSL2+)
DATA RATE INFORMATION
Upstream 440 (Kbps)
Downstream 283 (Kbps)
DEFECT/FAILURE INDICATION
Operation Data Upstream Downstream
Noise Margin 33.1 (dB) 38.6 (dB)
Line Attenuation 10.0 (dB) 22.0 (dB)
Indicator Name Near End Indicator Far End Indicator
Output Power 11.7 (dBm) 0.0 (dBm)
Fast Path FEC Correction -- --
Interleaved Path FEC Correction 0 0
Fast Path CRC Error -- --
Interleaved Path CRC Error 0 0
Loss Of Signal Defect 0 0
Fast Path HEC Error STR -- --
Interleaved Path HEC Error 0 0
Error Seconds 0 0
STATISTICS
Received Data 43498 (Kbits)
Transmitted Data 50857 (Kbits)
Anyone got any suggestions?
Solution
Accepted by topic author Wardie100
a week ago
Re: Help! New customer 0.3mbps broadband speed!
You should be syncing at about 19 Meg instead of the 283 K that you are. The reason you are not is that the DLM system has put you on a banded profile in response to past errors on your line, the lowest of these Banded Profiles, altho' you now have no significant errors. You need to call EE to reset the DLM in order to remove any banding. However should significant errors persist the DLM will reapply banding.
To phone EE: The local rate landline number 020 7362 0200 or Freephone 0800 079 8586 - Option 1 for Mobiles; Option 2 for 4G WiFi; Option 3 for Home Broadband & EE TV.
ISPs: 1999: Freeserve 48K Dial-Up => 2005: Wanadoo 1 Meg BB => 2007: Orange 2 Meg BB => 2008: Orange 8 Meg LLU => 2010: Orange 16 Meg LLU => 2011: Orange 20 Meg WBC
Solution
a week ago
All sorted. DLM reset and 18.6Mbps restored.
If you need any help in the future @Wardie100
Please do pop back.
Many thanks,
Lee
[ Edited ]
You're welcome Smiley Happy! Glad I could be of assistance.
Spot on, new sync speed Smiley Happy.
