by frosty2020 Investigator
HDD showing in Smart Hub Home but it does not apprear in My Network on Explorer
Morning all,
I have just had Fibre installed with the EE Smart Hub as the router. The router side is all working and i am getting good data speeds. I connected a WD HDD to the USB port and went to Explorer in Win 10 and the HDD is not listed. All my other devices are listed.
I logged on to the router and i saw all the connected devices listed including the HDD. However, if i click on the HDD it only has options to change the name of it and the icon.
Is there a setting i am missing to allow the HDD to be accessible accross my network?
Cheers
8 REPLIES 8
Re: HDD showing in Smart Hub Home but it does not apprear in My Network on Explo
@frosty2020   What size is the HDD there is a size limit.  I believe it’s 200GB
Ah well that wont work.... The HDD is 8TB !!!
@frosty2020  just slightly over the limit then.   😆
Just a little.
@Chris_B thanks for the info.
I don't believe there is a size limit, certainly not that low. What format is your HDD?
@frosty2020   Sorry it’s not 200GB it’s 2TB.  I do apologise.
@XRaySpeX  thanks for the update. The HDD is formatted to NTFS but its still a bit too big to allow my HDD to be visible.
@Chris_B  no problem
cheers both
NTFS is fine; looks like size isn't.
Recent solutions
