by MrLeoSir1
Getting faster speeds, and lower pings
I am new to EE broadband and the guys on the phone tells me that there is nothing they can do to get faster speeds or faster pings.
Is this correct? ( I have come from virgin)
So last time I had a BT connection broadband was some time ago and they used to be able to change things and get things to be faster.
I'm seeing pings of 24ms and 62mbps down 20mpbs up.
Does anyone know?
I am btw using ethernet and not wifi.
Thank you
Re: Getting faster speeds, and lower pings
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
4. What does BT Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number, use the Address Checker, not the Postcode Checker.
5. What is the ping to BBC.co.uk?
by MrLeoSir1
sure here you go.
Product name:Smart Hub
Serial number:+EEH001+1913000301
Firmware version:v0.00.24.06190-EE
Firmware updated:Your Firmware has not been updated.
Board version:01
DSL uptime:1 Days, 4 Hours, 2 Mins, 22 Secs
Data rate:20.00 Mbps / 64.17 Mbps
Maximum data rate:22.01 Mbps / 64.62 Mbps
Noise margin (up/down):6.7 / 6.0
Line attenuation (up/down):20.6 / 16.6
Signal attenuation (up/down):20.4 / 16.5
Data sent / received:45.1 GB / 11.6 GB
Broadband username:
2.4 GHz wireless network name:EE-Hub-N9Hw
2.4 GHz wireless channel:Smart (Channel 1)
5 GHz wireless network name:EE-Hub-N9Hw
5 GHz wireless channel:Smart (Channel 48)
Wireless security:WPA2
Wireless mode:Mode 1
Firewall:Default
MAC address:64:CC:22:69:70:88
Software variant:-
Boot loader: 0.0.3-EE (Mon Dec 4 17:32:53 2017)
Pinging bbc.co.uk [151.101.0.81] with 32 bytes of data:
Reply from 151.101.0.81: bytes=32 time=18ms TTL=50
Reply from 151.101.0.81: bytes=32 time=26ms TTL=50
Reply from 151.101.0.81: bytes=32 time=36ms TTL=50
Reply from 151.101.0.81: bytes=32 time=20ms TTL=50
Ping statistics for 151.101.0.81:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 18ms, Maximum = 36ms, Average = 25ms
there you go.
