Highlighted
by Contributor
Flashing green light no internet
How come I get a flashing green light - the long bar one - and no internet? Any ideas? It happens increasingly more each week. Thoughts appreciated people
18 REPLIES 18
Highlighted
Re: Flashing green light no internet
@Binme : Welcome to EE's Home Broadband Forum.
Green should not be flashing but steady, meaning it's starting up.
Have you just joined EE BB or were you already with EE BB?
What does it say after you log into the router:
  • For a BrightBox: in the Internet section on the initial Status page or
  • For a Smart Hub: on the Advanced Settings / Broadband / Internet page?
Obscure your names & numbers in the BB Username but post the 1st 2 parts of the IP addy. This will tell us at which stage EE have got to.
Is this for ADSL BB or Fibre? Which router, BrightBox 1 or 2 or Smart Hub?
Does the phone work? Do you get a dial tone? Does it announce your correct no. when you dial 1470 17070?
Highlighted
by Contributor
Had shed loads of issues with no internet and I’ve noticed this flashing a few more times. The unit was not being restarted or rebooted just sat there for the 2nd time this week. It is really annoying me and if it keeps up will go back to complaining and moving. I have no idea about looking at advance settings though.
Highlighted
by Contributor
It did say there was no internet connection btw during the flashing.
Highlighted
How about the info I requested? I cannot comment until I see it.
Highlighted
Our broadband Tech Gurus may be able to help you, @Binme
Otherwise, please send over the information that @XRaySpeX asked for. 🙂
Highlighted
by Contributor
I’m late in replying but you know how things take your time.
Broadband is fibre and the unit is the smart one (like this one https://shop.ee.co.uk/broadband/smart-hub). I shall try to get the info from the unit later tx
Highlighted
by Contributor
That didn’t seem to post. I’ve been busy and that info is Broadband is fibre and the unit is the smart hub.  I need to get that other info later today though. Tx
Highlighted
Thanks, I'll wait on it.
Highlighted
by Contributor
this is the info from the window you asked for, that ok?Screenshot 2019-04-23 at 10.03.18.png
Highlighted
by Contributor
take 2
Highlighted
by Contributor
or is this the info you wanted, the terms are a little confusing 🙂 Screenshot 2019-04-23 at 10.09.31.png
Highlighted
Well, your BB is running fine at full speed.
How often do these discons occur?
Would you also  post your full router stats.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
Highlighted
by Contributor
the signal goes once or twice a week which is really annoying during a film! Using both apple and Windows products.
when it works it is okay.
Product name
EE Smart Hub
Serial number
Firmware version
v0.00.24.06190-EE (Tue Jun 19 17:25:19 2018)
Board version
1
Data sent / received
463.0 MB / 1.1 GB
DSL uptime
1 days 10 Hours 32 Mins 53 Secs
Data rate
8.86 Mbps/40.00 Mbps
Maximum Data rate
9.0 Mbps/50.4 Mbps
Noise margin (up/down)
7.3/8.9
Line attenuation (up/down)
26.5/20.8
Signal attenuation (up/down)
25.6/20.6
Broadband username
2.4 GHz wireless network name
EE-K
2.4 GHz wireless channel
Smart (Channel 1)
5 GHz wireless network name
5 GHz wireless channel
Smart (Channel 48)
Wireless Security
WPA
Wireless mode
Mode 1
Firewall
Default
MAC address
BC:30:D9:10
Software variant
Boot loader
0.0.3-EE (Mon Dec  4 17:32:53 201 7)
Highlighted
Once or twice a week isn't too bad.
Reboot the router & try plugging it into the hidden test socket that is revealed when you remove the bottom half of the split faceplate (2 screws or press tabs) of your master socket. Only do this if you have a split faceplate. Do you have any extension sockets in the home even if unused? Are there any wires connected to back of faceplate of master socket?
Try the BT Quiet Line Test (dial 17070 Opt 2), preferably with a corded phone, in the test socket with the router disconnected. If there is any noise, report it to your landline provider as a voice fault (don't mention Broadband). Often sorting out voice faults will fix the Broadband as well.
Post the full router stats & System Uptime when plugged into test socket.
Is the issue any better?
Highlighted
by Contributor
I'll let you know later - that may be a few days before I'm back though 🙂
tx
Highlighted
by Contributor
Yesterday got a call from the proactive team (who'd have thought...) and they rebooted something to increase the speed and reliability as they had seen it all slow to a British rail train.
No further problems so far but i shall be looking at your prompts and guidance XraySpeX to monitor how the broadband goes. Cheers. D
Highlighted
by Contributor
Hi again
having said all that got this on the log as it all went offline again.
phone line okay and clear by the way and flashing yellow green colour
anything there i should be concerned about?
This is getting annoying EE if it increases like it did last time and the broadband becomes functionally useless.
10:12:41, 26 Apr.System up
10:12:40, 26 Apr.Detect and configure Ethernet port1 as LAN
10:12:40, 26 Apr.Hub has activated against the device management system
10:12:40, 26 Apr.WAN Auto-sensing last connection port: DSL WAN
09:59:55, 26 Apr.PPP: Stopped PPP daemon(0,1,5)
09:59:55, 26 Apr.PPP: Starting PPP daemon
09:59:54, 26 Apr.DSL Link Down: duration was 20 seconds
09:59:54, 26 Apr.WAN Auto-sensing detected port DSL WAN
09:59:54, 26 Apr.DSL Link Up: Down Rate=22176kbps, Up Rate=7660kbps; SNR Margin Down=0.0dB, Up=0.0dB
09:59:11, 26 Apr.WAN Sensing Auto sensing Complete, interface selected
09:59:10, 26 Apr.WAN Sensing Auto sensing Running
09:59:10, 26 Apr.WAN connection WAN2_INTERNET_PTM disconnected.[ERROR_NO_CARRIER]
09:59:04, 26 Apr.PPP: Stopped PPP daemon(0,1,5)
09:59:01, 26 Apr.PPP LCP Send Termination Request (User request)
09:58:58, 26 Apr.PPP LCP Send Termination Request (User request)
09:58:58, 26 Apr.PPP: IPCP down
09:58:58, 26 Apr.PPP: LCP down
Highlighted
What are the full router stats to go with that log?
You really need to do my tests from the test socket.
Thanks! You're welcome :)! Glad I could be of assistance.
