by Garth3 Investigator
Flashing Orange Internet Light
We've just been automatically upgraded to Bright Box as our old one blew up in the middle of a thunderstorm. The new one arrived, we had the email to say we were live, so I've set it up and all lights are been receipt for a flashing orange next to Internet. I've been fishing round these forums for a solution but it's all double Dutch to me.
One person said this is a problem between EE and BT at the green box up the road. Anyone else have any idea?
Thanks!
Solution
Re: Flashing Orange Internet Light
You are fully connected to BB but you have not passed authentication by EE to go onto the Net. You should be seeing "PPP: CHAP authentication failed" msgs in the System Log.
Are you sure you have your BB Username & pwd correct?
9 REPLIES 9
by liggerz87 Established Contributor
Sorry this not much help have you checked the wires as before the plug you use to go into router to get the internet I accidentally put it in an ethernet port before and waited an hour and unplugged and re plugged it and it started working lol of done all that might be best to call ee
Thanks for the help, but yeah, checked all the cables. Phone line works. Log in to the ee admin screen and everything looks good except 'internet state' which is disconnected.
Dont have clue then could you try the reset button with a pin to see if that would help think best to call but others on here may be more help
It could well have the makings of a problem between EE and BT but much further afield than the cab up the road.
What does it say after you log into the router:
  • For a BrightBox: in the Internet section on the initial Status page or
  • For a Smart Hub: on the Advanced Settings / Broadband / Internet page?
Obscure your names & numbers in the BB Username but post the 1st 2 parts of the IP addy. This will tell us at which stage EE have got to.
Does the phone work? Do you get a dial tone? Does it announce your correct no. when you dial 1470 17070?
Thanks for the reply. Phone gives correct number when dialling 1470 17070. Here's the rest of it:
Broadband TypeADSL
Broadband StateConnected
Internet StateDisconnected
Time Connected00:00:00
Downstream Rate8.51 Mbps
Upstream Rate1.28 Mbps
IP Address0.0
Broadband Username *******@fs
Thanks!
Solution
That was it! Not sure what password we had in there but it wasn't the right one. Easy when you know how, I guess. Stunning work, thank you so much!!!
Thanks! You're welcome 🙂 ! Glad I could be of assistance & it is now sorted.
Glad it got fixed for you
