by pinewapple Contributor
Fibre regrade speed now worse
So ordered the fibre regrade and it happened earlier this morning i was actually up at the computer but notice only my upstream sync speed went up my downstream sync speed actually lowered slightly from 40.00mbps to 36.34mbps
Product name:Smart Hub
Serial number:+EEH001+1829010347
Firmware version:v0.00.24.06190-EE
Firmware updated:Wed Sep 26 11:21:54 2018
Board version:01
DSL uptime:0 Days, 0 Hours, 9 Mins, 17 Secs
Data rate:17.64 Mbps / 36.34 Mbps
Maximum data rate:17.64 Mbps / 42.15 Mbps
Noise margin (up/down):5.9 / 6.1
Line attenuation (up/down):22.1 / 16.6
Signal attenuation (up/down):22.0 / 16.5
Data sent / received:13.7 MB / 94.1 MB
Broadband username:PRODUCTIONHQNUN368191801@fs
2.4 GHz wireless network name:EE Hub R8
2.4 GHz wireless channel:Smart (Channel 11)
5 GHz wireless network name:EE Hub R8
5 GHz wireless channel:Smart (Channel 48)
Wireless security:WPA2
Wireless mode:Mode 1
Firewall:Default
MAC address:4C:1B:86:45:85:2E
Software variant:-
Boot loader:0.0.3-EE (Mon Dec 4 17:32:53 2017)
15 REPLIES 15
Re: Fibre regrade speed now worse
What does BT Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number, use the Address Checker, not the Postcode Checker.
Thanks for reply
Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Handback Threshold(Mbps)WBC FTTC Availability DateWBC SOGEA Availability DateLeft in Jumper  High Low High Low        Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)WBC FTTP Availability Date
ADSL ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)Availability Date
Left in JumperObserved SpeedsVDSLOther Offerings
Availability Date
Premise environmentStatus
VDSL Range A (Clean)79.456.62018.351.1AvailableAvailable--
VDSL Range B (Impacted)77.552.92016.645.4AvailableAvailable--
FTTP on Demand33030--Available----
WBC ADSL 2+Up to 6--4 to 8Available----
WBC ADSL 2+ Annex MUp to 6Up to 14 to 8Available----
ADSL MaxUp to 5--3.5 to 7.5Available----
WBC Fixed Rate2----Available----
Max Observed Downstream Speed (Mbps)42.15
Max Upstream Observed Speed (Mbps)17.01
Observed Date2019-04-26
VDSL Multicast------Available----
ADSL Multicast------Available----
Bridge TapU
VRIN
NTEFaceplateN
Last Test Date11-07-2019
Yes, you should probably be getting 70+ Meg.
What are all EE's contractual speed estimates given in your MyEE for BB under Your broadband speed ?
this is in the contract thing
We estimate your line will support downloads between 48.1Mb/s and
72.3Mb/s and uploads between 15.1Mb/s and 18.2Mb/s – your
minimum guaranteed speed is 41.3Mb/s.
and from site
Minimum Fibre Download Speed is 48.1 Mb/Sec
Maximum Fibre Download Speed is 72.3 Mb/Sec
Minimum Fibre Upload Speed is 15.1 Mb/Sec
Maximum Fibre Upload Speed is 18.2 Mb/Sec
Minimum Guaranteed Download Speed is 41.30 Mb/Sec
Complain to EE that you are not even getting the min guaranteed speed of 41.3 Meg when you should be getting 70 Meg.
Hi there @pinewapple
If you get in touch with our Broadband Gurus they will be able to get this looked into further for you.
Let us know how you get on.
Thanks all made a complaint earlier on the site i shall update this when i get some info thanks
Hi @pinewapple
Just noticed internet dropped out for about 30 seconds maybe and speeds up by about 10Mbps
Board version:01
DSL uptime:0 Days, 0 Hours, 5 Mins, 7 Secs
Data rate:17.70 Mbps / 45.27 Mbps
Maximum data rate:17.70 Mbps / 45.98 Mbps
Noise margin (up/down):6.0 / 5.2
Signal attenuation (up/down):21.9 / 16.6
Data sent / received:6.7 MB / 138.5 MB
Firewall:Default
Software variant:-
Still below EE's minimum down speed.
Board version:01
DSL uptime:0 Days, 0 Hours, 22 Mins, 43 Secs
Data rate:17.70 Mbps / 47.83 Mbps
Maximum data rate:17.70 Mbps / 48.28 Mbps
Noise margin (up/down):5.8 / 4.2
Line attenuation (up/down):22.3 / 16.7
Signal attenuation (up/down):22.1 / 16.7
Data sent / received:17.3 MB / 409.0 MB
Firewall:Default
Software variant:-
another slight increase about 30 minutes ago only by about 2mbps this time, Is this DLM slowly increasing which band i am in? Although in the first please was never on the highest.
Also got a text/email today regarding my complaint i think;
"Sorry you have a fault. We're fixing it and will keep you updated. View our troubleshooting tips: ee.co.uk/broadband-help. The fault reference no is 324096685"
Thanks for coming back to us.
If you would like an update on your open reference number give us a call so the team can get this looked into for you.
Leanne 🙂
Still not any higher than last post which i dont think is very good, have had sky before and received full speeds no problem before. EE not much help pretty much saying im getting the minimum.
Is it possible to get a DLM reset? As surely when my regrade went through it should have went up to the highest sync speed and dropped from there if was problem? But it seems mine has slowly went up.
What would you think?
Thanks for coming back to the community 🙂
We will help you get this looked into, I have sent you a private message for some details
Speak soon.
