by davpreec Established Contributor
Fibre problems, internet connected but some sites will not load
Hi guys i randomly got disconnected about 2 hours ago and have reset my routor ect , For some reason my internet is sort of half working, some sites work and others don't (like youtube,facebook, even google is not working) but other random sites load up fine??
Not sure if there's a EE fibre issue or not this has never happened before.
Has this happened to anyone else? I also can't connect to my xbox one for some reason.
Everything was fine before the random disconnect.
Dave
Solution
Re: Fibre problems, internet connected but some sites will not load
Seems to be working fine now panic over hahaha that was strange 😕
Solution
Hi @davpreec
Welcome back to the community.
Glad this is working for you.
If you have any trouble in the future, see our How can I fix my home broadband connection? Help page for steps to try 🙂
Have a great day.
Thanks 🙂
