Highlighted
by Investigator
Fibre buffers at peak times even on low size files when streaming. Why?
My fibre broadband has started to buffer quite badly when I am streaming at peak times (evenings and all weekend).
This happens on even small size files, I cannot get through a film at all without it buffering all the time.
Any thoughts?
I do know that I am at the far end of the exchange's range.
Highlighted
Re: Fibre buffers at peak times even on low size files when streaming. Why?
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
4. What does BT Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number, use the Address Checker, not the Postcode Checker.
