by baileybronson80 Valued Contributor
Valued Contributor
Fibre broadband not working??
My fibre wifi broadband randomly stopped working... the lights on the hub went red, so I turned it off, waited 5 mins, forgot the network on my phone, then switched it back on..
I then reconnected to the Wi-Fi on my phone, it says it's connected but says, internet may not be available.
When I try to use my Samsung tablet, it says the same thing, as ij it will connect, but says internet may not be available, but if I then try to go to Google, it says, your connection is not be private...??!!
Can anyone help??
I've done the bt openreach thing, and there's no faults reported  in the area, I dont have a landline to check my phoneline, and i don't have anything that has an Ethernet socket in it to plug in directly!
Of course I can call ee in the morning, but I'm a bit of a night owl and struggling to sleep, so hoping there's someone else out there awake that can maybe help?! Lol..
Thanks 🙂
31 REPLIES 31
Valued Contributor
Help!!! Fibre broadband... working but no internet??
Can anyone help??
Thanks 🙂
Re: Help!!! Fibre broadband... working but no internet??
@baileybronson80 : @Welcome to EE's Home Broadband Forum
Which router? What colour are which lights now?
What does it say after you log into the router:
  • For a BrightBox: in the Internet section on the initial Status page or
  • For a Smart Hub: on the Advanced Settings / Broadband / Internet page?
Obscure your names & numbers in the BB Username but post the 1st 2 parts of the IP addy.
Does the phone work? Do you get a dial tone? Does it announce your correct no. when you dial 1470 17070?
Valued Contributor
Sorry for the delay, tried to write a reply while connected to wifi and i think it deleted the whole thing!!
Thanks for replying!
The lights are teal/blue colour, which means it should be working?!
I don't have a landline to test the line unfortunately...
On the Samsung tablet it says,
Ee hub
Connected
Network speed 173 mbps
Security wpa2 ...
Ip address - 192.168.1.66
Manage router - 192.168.1.254
But when I try to go to any webpage, it tells me that my connection is not private and that attackers might be trying to steal my information..???
Hope this means something to you cos it means nothing to me!
Thanks 🙂
Valued Contributor
But my phone has different router numbers... I'm not sure if that's normal or not?!
My phone says,
Connected then changes to...
Internet may not be available
Network speed 685 mbps
Security - WPA2 ..
IP Address- 192.168.1.223
Confused!!
Valued Contributor
Anybody any ideas??!
The page I asked for please & is the router an EE Smart Hub?
Maybe when you give me the info I want.
Valued Contributor
Yes I think it's a smart hub?? Is this the page you're after??
Sorry I'm kind of useless with this technical stuff..  at 30 years old I've kind of lost my touch!! 😛
EE Smart Hub Manager
advancedPage
Broadband
Internet
VPN
Dynamic DNS
Connection status
Connection status:
Connected
Downstream:
40.00Mbps
Upstream:
10.00Mbps
Connection information
Connection time:
0 Days, 0 Hours, 1 Mins,
1 Secs
Data usage:
0.0 MB Uploaded /
0.0 MB Downloaded
Broadband username:
Password:
TCP/IP information
Broadband IP address:
109.249.90.70
Default gateway:
213.1.79.250
DNS Type:
Auto
Manual
Primary DNS:
78.33.48.80
Secondary DNS:
87.237.17.166
WAN Port
WAN Port:
Thanks again 🙂
Valued Contributor
Sorry I didn't know what you meant and only just seen these msgs!! My phone signal and phone internet is so bad in my house...Which is why i got the broadband so as I could use my phone with Wi-Fi calling and the internet! 😕
You should be connecting to the Net with that.
  • on the Advanced Settings / My Network page?
Valued Contributor
I have no idea what I did, or if it will stay fixed... but I went into that advanced settings page, (that you told me to go into ages ago, but i didn't know what you meant) tried to do a test thing, and it said it has reset my router back to original settings, if I had changed username or passwords it will revert to original, and now its instantly working?! I never changed my username or passwords so I'm not sure as to why it decided to stop working!!
Is it advised to change my passwords now?
Does it mean someone was hacking my internet?!
Thanks for your help!!
I'm not surprised!
Nobody's been hacking you.
Thanks. Glad I could be of assistance and it's now sorted.
Valued Contributor
Lol thank you very much!
I will remember that page from now on !!
Does it mean anything then, if, on that page, when i go to my network then my devices, that there are some on there that i don't recognise or that say unknown?!
You should get paid for your advice!
Don't just talk about them; please show me them..
Valued Contributor
Okay so there's this one-(which isn't now connected I guess due to the reset)
android-ed437d1bf097d7d7
Click Icon to Change
Connection Status:
Not connected
IP Address:
192.168.1.71
MAC Address:
A8:A1:98:5C:5C:FE
Connection Type:
Wireless
Address Assignment:
DHCP
Always use this IP Address:
IPv6 addressing
This device either does not support or is not configured for IPv6 addressing
Port forwarding
No Port Forwarding rules have been set for this device.
EE access control
No Access Control times have been set for this device.
And this one...
twork
unknown_00:90:A2:90:36:2F
Connection Status:
Not connected
IP Address:
192.168.1.89
MAC Address:
00:90:A2:90:36:2F
Connection Type:
Wireless
Address Assignment:
DHCP
IPv6 addressing
Port forwarding
EE access control
Valued Contributor
Oh and this one...
advancedPage
My Network
Galaxy-S8
Connection Status:
Not connected
IP Address:
192.168.1.107
MAC Address:
04:D6:AA:22:1A:F7
Connection Type:
Wireless
Address Assignment:
DHCP
IPv6 addressing
Port forwarding
EE access control
A past visitor to your home with an S8.
Valued Contributor
Okay yeah that could have possibly been my brother...
Any ideas on the Android or the unknown that I sent above that??
Valued Contributor
Are they possibly dodgy??
I don't normally worry about things like that but cos my internet went down then kept telling me my connection wasn't safe and someone could be attacking my files etc .. I'm now a bit concerned?! Lol...Thanks!!
