Highlighted
by Investigator
Fibre Broadband Disconnecting
I've an issue where the broadband disconnects constantly. The period between disconnects can be as little as a few minutes to several hours. The frequency of disconnects seems to align to peak times; although this might be my imagination.
The router LED usually cycles through: flashing yellow - yellow - (sometimes red) - (sometimes flashing aqua) - aqua.
These disconnects usually only last a few minutes.
Any help is appreciated.
Happy to provide router logs / further information as required.
Regards,
Highlighted
Solution
Re: Fibre Broadband Disconnecting
Locate the hidden test socket that is revealed when you remove the bottom half of the split faceplate (2 screws or press tabs) of your master socket. Only do this if you have a split faceplate. Do you have any extension sockets in the home even if unused? Are there any wires connected to back of faceplate of master socket?
Try the BT Quiet Line Test (dial 17070 Opt 2), preferably with a corded phone, in the test socket with the router disconnected. If there is any noise, report it to your landline provider as a voice fault (don't mention Broadband). Often sorting out voice faults will fix the Broadband as well.
Reboot the router & plug it into the test socket. Post the full router stats & System Uptime when plugged into test socket.
Is the issue any better?
6 REPLIES 6
Highlighted
Post your full router stats:
  • For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
  • For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information. Obscure your names & numbers in the BB Username & also the SSIDs.
Highlighted
by Investigator
Thanks for the response!
Below I've posted the information from the technical log. I can provide information from the event log if that would help clarify.
Regards,
Product name:Smart Hub
Serial number:+EEH001+1936019876
Firmware version:v0.04.02.09120-EE
Firmware updated:Mon Feb 3 23:07:39 2020
Board version:01
DSL uptime:0 Days, 0 Hours, 0 Mins, 45 Secs
Data rate:17.29 Mbps / 58.66 Mbps
Maximum data rate:17.28 Mbps / 60.41 Mbps
Noise margin (up/down):6.0 / 6.5
Line attenuation (up/down):21.1 / 16.7
Signal attenuation (up/down):20.9 / 16.7
Data sent / received:0.4 MB / 2.0 MB
Broadband username:
2.4 GHz wireless network name:
2.4 GHz wireless channel:Smart (Channel 11)
5 GHz wireless network name:
5 GHz wireless channel:Smart (Channel 48)
Wireless security:WPA2
Wireless mode:Mode 1
Firewall:Default
MAC address: F0:86:20:65:FD:6C
Software variant:-
Boot loader:0.0.3-EE (Mon Dec 4 17:32:53 2017
Highlighted
Solution
Highlighted
by Investigator
Thanks again!
I think it may be sorted!
After contacting via phone twice I think you've helped located the source of the problem.
I removed the plate to locate the 'test socket'. There were no wires connecting the face plate to the master socket. The face plate just plugged in.
When connecting the line in directly to the master socket, without the face plate, I noticed that the connection seemed to be a little loose. When applying pressure to ensure a solid connection it has immediately increased the broadband speed and we have had a solid connection for ~25 minutes which is a record for today.
I will mark this as the solution in the next hour providing no issues!!
Could you advise the purpose of the face plate? Do I need to purchase and install another or is the current 'botch job' arrangement acceptable until BT openreach home visits are available at the end of may?
Thanks again, really appreciate your time!
Highlighted
Good. That's the whole idea of the test socket. To isolate the problem.
The removable faceplate was introduced by BT many years ago to allow consumers to self-install extension sockets in their homes. You only have wires connected to the back of the faceplate when you have other extension sockets in the home.
I usually get spare faceplates from a passing Openreach eng in better times but it sounds from what you say that it is the back box that is loose.
Thanks! You're welcome 🙂 ! Glad I could be of assistance & hope that it is now sorted.
Highlighted
Would you post your router stats now that it seems better?
