by Alanedmends
Ee broadband
I've had problems for nearly 2 months, I want my money back and cancel my contract without charges
Re: Ee broadband
What's the problems?
by Alanedmends
Re: Ee broadband
It keeps cutting out and resetting itself
Sometimes just stays red
Re: Ee broadband
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
