by MykeH Investigator
EE vs Sky
So EE rep tells me I'll get a better broadband than what I have with Sky, well with Sky i was constantly within 2-3 mbs download with EE sometimes I don't even get the minium promised (1.8) surely this is miss selling a service, I'm seriously not happy and to top it my sons University has closed and he has to do online study which he has found impossible at times as nothing will load. as for wifi thats a dead loss even with the boosters, was perfect with sky.
9 REPLIES 9
Re: EE vs Sky
  • For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
  • For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information. Obscure your names & numbers in the BB Username & also the SSIDs.
Re: EE vs Sky
https://www.thinkbroadband.com/speedtest/1585078265478724555
 samknows.com/broadband/exchange/LCMAR
DSL STATUS This page shows information about your DSL connection. If you are using Fibre/Ethernet Broadband then this page is not applicable.
STATUS  Configured CurrentLine StatusLink TypeOperation Mode
--UP
--Fast Path
AutomaticG.992.3 (ADSL2)
DATA RATE INFORMATIONUpstreamDownstream
579 (Kbps)
3095 (Kbps)
DEFECT/FAILURE INDICATIONOperation Data Upstream DownstreamNoise MarginLine Attenuation
8.1 (dB)3.0 (dB)
32.6 (dB)55.0 (dB)
Indicator Name Near End Indicator Far End IndicatorOutput PowerFast Path FEC CorrectionInterleaved Path FEC CorrectionFast Path CRC ErrorInterleaved Path CRC ErrorLoss Of Signal DefectFast Path HEC Error STRInterleaved Path HEC ErrorError Seconds
12.8 (dBm)0.0 (dBm)
00
1427196
00
173669
70321789
STATISTICSReceived DataTransmitted Data
6698887 (Kbits)
8934281 (Kbits)
System Uptime is: 189:20:36
Re: EE vs Sky
You are currently getting 3.1 Meg down sync. You do have a long line. You should get the same from EE as you did from Sky. You might get a bit faster by switching DSL Mode to G.DMT. Post your router stats again when you do so.
What does BT Wholesale Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number, use the Address Checker, not the Postcode Checker.
Re: EE vs Sky
Tried switching and it just killed everything, had to reverse back, on Sunday I ran aload of speed checks using testmy.net and it didn't hit 1 Mbs
Re: EE vs Sky
When you run speedtests you should keep an eye on the sync speeds. After all, that's what EE is selling you.
Re: EE vs Sky
I'm going to have to ring them as their wifi and boosters are not covering half the house, can only get wifi in the room with Modem without boosters and with them it only extends one room further not good enough,.
Thank you for your help.
Re: EE vs Sky
Thanks! You're welcome 🙂 ! Glad I could be of assistance.
Re: EE vs Sky
Here I am tonight and struggling to even connect to this page, EE  broadband has been a pain since I joined same with the wifi that is very poor even with the boosters, I had no problems with Sky only left because of the price, BIG mistake.
Re: EE vs Sky
Hi there @MykeH
I am very sorry to hear this.
If you give our Broadband Tech team a call, they will be able to get this looked into for you.
Let us know how you get on after speaking to them.
Recent solutions
