by benmisell Investigator
EE Smart Hub ethernet WAN
In my previous setup with the older bright box 2 I had it set up as using the ethernet connection from a pfsense box as it's wan. I can't find a similar option on the smart hub.
On the technical logs, in the WAN section there are messages saying "Detect and configure Ethernet port1 as LAN", so I suspect it may be possible.
Can anyone help me with this? A solution that involves firmware flashing is acceptable.
Re: EE Smart Hub ethernet WAN
It is set in routing. That dectecting port as lan or maybe wan is still
bothering me, as something is obviously possible. Port 4 on the back is
also marked with a red WAN label above it. How is that enabled?
You mean you set the BB2's Protocol to Routing or Bridging? You can't do that with the EE SH.
@benmisell wrote:
It is set in routing. That detecting port as lan or maybe wan is still
Which router are you talking about there?
The red WAN port 4 of the BB2 is the 1 you use when you have a WAN connection to it over Ethernet. The same must go for the EE SH. So I suppose that's the way to get Routing with it.
I am talking about the smart hub not bright box. It's one of the yellow lan ports, but there is a red WAN label above it. I can't find a setting for ethernet wan in the admin interface though.
I expect it is enabled simply by the presence on a WAN signal on that port.
