by Skilled Contributor
Skilled Contributor
EE Smart Hub Ethernet WAN?
Hi.
I am thinking of moving from BT to EE as there are dramatic savings to be had.
For various reasons, I need to use a Huawei BT Modem. Mainly, this is due to the fact that if I use a router anywhere else than the master socket, by connection speeds drop dramatically. (I am 1.2km from the FTTC cabinet).
Using a router sonnected via ethernet to the modem maintains the bext connection speed with the flexibility to place the router wherever I wish.
I found a discussion as to whether the new EE SH supports WAN connections (like the BB2 did) but no definitive answer.
Does the new SmartHub auto sense a modem? Is there a WAN port?
Thanks in advance.
Solution
Re: EE Smart Hub Ethernet WAN?
Yes, the EE SH is a rebadged BT Smart Hub 6B, the one designed for FTTP customers. Unlike the Smart Hub 6A, it has one of its yellow LAN connectors converted to a WAN port. This is identified with a Red sticker over port 4. However this does not prevent it being used just for FTTC.
Solution
Skilled Contributor
Thanks - just what was needed!
It is interesting that onmany routers that simply extending the connection cable to the vdsl socket (even with high quality cables), the throughput decreased dramatically - especially when 1.5km from the cabinet.
Using an OpenReach modem and ethernet cable to the router/hub solves all these issues.
Thanks! You're welcome :)! Glad I could be of assistance.
