by dylanbatt74
EE STATIC IP
Hello,
Im concerned now,
after speaking with an EE adviser while ordering my EE fibre, i asked him 3 times if i get a static IP , as i host a small web-server and email i need this
I currently have SKY with this feature and its been fine, but out of contract and EE prices are better
Does anyone know about this, all i can go off is the answer of YES from the Adviser and he went off pheone to ask, As if this is not the case i will be really P~~ssed at them !!
Solution
Re: EE STATIC IP
@dylanbatt74 : Yes, EE CS & sales staff are under the mistaken impression that "Static IP" refers to the private LAN IPs of your devices. i.e. the 192.168.1.x subnet, rather than your public external IP.
by Ace Contributor
Re: EE STATIC IP
Hi @dylanbatt74
Welcome to the EE Community,
unfortunately EE don't supply static IP addresses.
Thanks,
David.
by dylanbatt74
Re: EE STATIC IP
So i am being told incorrect information on a recorded call, this should be fun !
Solution
Re: EE STATIC IP
