by hannahibarney
EE Router broadband dropping out, showing red light
Hello, I have had a search through the topics already and have tried to fix my issue but have had no success.
Right now I have all 3 green lights showing on my bright box 2 but the minute any of us try to connect with the PS4 or Xbox to stream anything the whole thing drops with a red light on the broadband and boots up all green lights but then just continuly drops out until we give up. Even typing this out I am having small issues. I have tried to log on to the internet status but nothing makes much sense to me.
Not sure what information you need to diagnose it but just ask and I can send it. I am trying to avoid ringing EE if possible as I work shifts and can't spend a lot of time hanging around on the phone.
Any help is appreciated.
Hannah
Re: EE Router broadband dropping out, showing red light
If you would like help with your BB speed or connection issues, please would you carry out the following steps for starters, whilst all green lights show (don't attempt any other work while you do so), which will enable us to diagnose the problem and advise you further. Do not restart your router to do these tests:
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
