by elmerlloyd2
EE Fibre Plus - ADSL filter?
I have EE Fibre Plus which has a minimum guaranteed speed of 54Mbps but I get 30-40Mbps, I'm trying to figure out why. I've noticed that the microfilter I got with the Smart Hub is an ASDL filter but I understand FTTC is VDSL, is this the reason why my internet is slow?
Re: EE Fibre Plus - ADSL filter?
No, it makes no diff.
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
4. What does BT Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number, use the Address Checker, not the Postcode Checker.
