by JamiePay Investigator
EE Broadband disconnecting constantly in 2 week slots for the past year.
I have been getting constant droppings of my connection on and off over the past year. I used to be with BT and thats when the disconnections started. Every couple  of weeks, the connections starts dropping 10+ times a day for about 2 weeks. After about 2 weeks, the connection is fine for a couple of weeks before repeating the disconnections. When i changed to EE in I think October it was fine until a couple weeks later when it resumes the constant drops. Lately it has gotten a lot worse with it going on for 4 weeks now. I am plugged into the hidden port and this didnt help either. Any help on what else I can try? Thank you.
9 REPLIES 9
Re: EE Broadband disconnecting constantly in 2 week slots for the past year.
Well, whatever it is you've brought it from BT with you. Still it's the same BB network, so you'd expect that.
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
e874461e48f467060f797b3610ce11a2.pngI have my PC upstairs and cannot bring it downstairs to do the Wired test. My Macbook also dosent have a Eithernet port on it so i did a wireless test. The D/U speed is not really a issue to be honest.
https://www.thinkbroadband.com/speedtest/1554910490116231055
https://availability.samknows.com/broadband/exchange/WMHAS
Your BB connection looks fine. You are getting 74 Meg sync speed. However your wireless speedtest does look an issue, delivering only about a third of router speed.
Reboot the router & try plugging it into the hidden test socket that is revealed when you remove the bottom half of the split faceplate (2 screws or press tabs) of your master socket. Only do this if you have a split faceplate. Do you have any extension sockets in the home even if unused? Are there any wires connected to back of faceplate of master socket?
Try the BT Quiet Line Test (dial 17070 Opt 2), preferably with a corded phone, in the test socket with the router disconnected. If there is any noise, report it to your landline provider as a voice fault (don't mention Broadband). Often sorting out voice faults will fix the Broadband as well.
Post the full router stats & System Uptime when plugged into test socket.
I think the wireless test was so low because i am downloading a game on my PC right now, normally it is hitting about 45/55. The connection is always plugged into the test socket as this is what BT told me to do last year. This is also the only place in the house as another one was cut off years ago. When i ring the phone on the quiet line, i hear a quiet fuzzy noise, could this be an issue?
@JamiePay : You sure it's in the test socket? You have removed the front faceplate completely? That is not normal advice from the engs. Don't you just mean the master socket is the only one in the house? I'm asking you to get inside it.
The QLT at a test socket should be completely silent.
I have had the face plate of the master socket removed for about a year with the cable plugged straight in?
A week on and there is still multiple disconnections a day and i really dont know what to do? Do i get an engineer or?
All you can do now is report it to EE.
How do you know it's the BB that's dropping & not just the WiFi? Does the router lose its steady Aqua light when it happens?
