by whisky_wonderer
DrayTek Vigor 2830n - Connection to EE Network
I am trying to connect my DrayTek router to the EE network, but without success.
I have check and changed all of the settings mentioned in related posts. I have also upgraded the routers firmware to the latest available, and triple check my logon credentials.
My current ISP connection configuration currently looks like the following. However, I don't have the option to select 'WAN Connection Detection' mode to 'PPP Detect', or to add a 'Separate Account for ADSL' . Other than that, my configuration is the same as other posts.
Any help would be greatly appreciated...
Re: DrayTek Vigor 2830n - Connection to EE Network
@whisky_wonderer : You are using that router on a standard ADSL connection? It is no good for Fibre.
What options does it offer for "Mode"?
What happens when you try to use it with your current settings as shown?
by whisky_wonderer
Hi XRaySex,
Thank you for the prompt reply.
I’m using a standard ADSL connection. I have also used the same ADSL filter and cable between both router, as this illuminates these as faulty parts.
Under the ‘Mode’ option, I only have two options - which are: “ARP Detect” and “Ping Detect”.
Using the Draytek settings in the screenshot, I cannot connect to the EE network at all. When I switch back to the EE router internet access is fine. I am using a WAN IP via PING to Initially check for an internet connection.
Kind regards.
When using the Draytek settings in the screenshot, what does its DSL or WAN Status say?
Recent solutions
