by Mleanne019 Contributor
Does anyone know how u check minutes left on ur home phone package
How do u check remaining minutes on ur home phone calling plan plz
Solution
Re: Does anyone know how u check minutes left on ur home phone package
@Mleanne019: Does it not tell you under your Member's Centre @ https://web.orange.co.uk/r/login/ ?
Solution
Hi @Mleanne019
Thanks for stopping by community again 🙂
I hope the great information supplied by @XRaySpeX has given you the information you needed.
Thank you
Richard
