by Djinger1989
New Member
Do EE use BT fibre infrastructure?
Solution
Re: Do EE use BT fibre infrastructure?
Yes, entirely. It is BT Openreach who run & supply Fibre BB.
You can find what Fibre you can get from any ISP by using the BT Broadband Availability Checker for your phone number. Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number, use the Address Checker, not the Postcode Checker.
Solution
EE Employee
Hi @Djinger1989 and welcome to the community.
I hope the information that @XRaySpeX has provided has helped 🙂
Many thanks,
Lee
