by Meenaghan23
New Member
Diverting Calls from Landline
Does anyone know how to divert calls from a landline to either another number
I want to be able to divert landline calls to any number I choose which may at time change?
Solution
Re: Diverting Calls from Landline
Yes, but you need to pay for it by buying All You Need To Know About Call Plus add-on.
Solution
