by crystamartin
Disable SMS on landline?
What it says on the tin, really. We keep getting text messages sent to the landline.  I'd like to turn this option off entirely as they come through at silly times and wake people up, but wasn't able to find any info on how to go about this. Can someone point me in the right direction?
by Ace Contributor
Re: Disable SMS on landline?
Hello @crystamartin it is not possible to disable incoming text messages I am sorry. What landline phone do you have? You may be able to block the number using the handsets settings.
Try phoning 1470 0800 587 5252, Opt. 1, 5. This is a BT Text service. It may not work on EE. In which case you might have to phone CS to switch it off.
Hi @crystalmartin
Welcome to the community. 🙂
Did the advice above help you get this sorted?
