by PercyVeer Contributor
Deleting devices connected to Livebox
I have several WiFi devices connected to my livebox which appear as MAC addresses in the Devices Connected to my Network list in the Inventel 192.168.1.1 pages.
Many of these are no longer used so I would like to delete them. But I can't see a way to do it. Any help will be appreciated. Thanks
Solution
Re: Deleting devices connected to Livebox
Hi @PercyVeer
I don't think you can delete them if they are just a log of devices which have previously used your network. You can try resetting your box which should reset the logs.
8 REPLIES 8
Solution
Hi @PercyVeer
Hi @PercyVeer,
Welcome back to the EE Community.
I would expect these devices to stop showing in your connected devices automatically.
Are you still using an Orange Livebox rather than an EE router?
@PercyVeer : You can't delete them unless you do a factory reset, but they're not doing any harm.
Thanks for your reply.
The livebox is working ok I was just attempting a tidy up. Thanks
The livebox is working ok and I was just attempting a tidy up. I will leave the old addresses there rather than reset the box as I will have to reconnect my current devices. Thanks again
Hello James
Thanks for your reply. Yes it is an Orange Livebox and its its working OK. I was just attempting a tidy up and as the only way to remove the old addresses seems like a reset I will leave them alone.
(Sorry I haven't yet got the hang of replying to individual posters but thanks to all who have responded)
No problem @PercyVeer 🙂
Don't hesitate to get in touch with Customer Care if you'd like to switch to a new EE Router.
Thanks again for visiting the Community.
Thanks! You're welcome 🙂 ! Glad I could be of assistance.
