by 1000green Established Contributor
Cwmp
Is cwmp the dlm?
Wondering it’s only happens one a day l, 10:04 everyday.
Many thanks Jordan
11 REPLIES 11
by Skilled Contributor
Skilled Contributor
Re: Cwmp
No, its the router call home site.
What is happening every day ?
Re: Cwmp
Skilled Contributor
Re: Cwmp
So do you have any issues with your service?
Or are you just looking at router logs for the first time?
Re: Cwmp
No, that's the TR-069 remote management run by EE on its network only when you 1st connect to its BB or when it wants to update the firmware. What only happens once a day? It's quite possible that each day the router checks back with EE whether it wants to do anything.
The DLM is run by OR at the DSLAM in your cab. For more on the DLM have a read of Kitz - DLM System
Re: Cwmp
Anyway you can check if your router has been disconnected, or dropped syncs? Thanks Jordan
Re: Cwmp
Trying to see if my connection if it has dropped or gone weaker
Re: Cwmp
On G.Fast the router knows nowt of the BB signal other than that the modem's gone down. It's all done in the G.Fast modem.
Re: Cwmp
Any weird behaviors?
192.168.1.97) RSSI=-74, Rate=0Mbps, host iPhone
10:41:33, 04 Sep. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT
10:41:33, 04 Sep. Receive a DHCP request
10:41:28, 04 Sep. DHCP device Disconnected: 192.168.1.97, b0:48:1a:7c:a9:94, iPhone
10:41:23, 04 Sep. 5G Client disassociate from b0:48:1a:7c:a9:94 (IP=192.168.1.97) RSSI=0, Rate=0Mbps
10:41:11, 04 Sep. DHCP device Connected: 192.168.1.97, b0:48:1a:7c:a9:94, iPhone
10:41:11, 04 Sep. 5G Client associate from b0:48:1a:7c:a9:94 (IP=192.168.1.97) RSSI=-68, Rate=0Mbps, host iPhone
10:41:11, 04 Sep. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT
10:41:10, 04 Sep. Receive a DHCP request
10:40:50, 04 Sep. DHCP device Disconnected: 192.168.1.97, b0:48:1a:7c:a9:94, iPhone
10:40:44, 04 Sep. 5G Client disassociate from b0:48:1a:7c:a9:94 (IP=192.168.1.97) RSSI=0, Rate=0Mbps
10:04:59, 04 Sep. NTP synchronization success
10:04:46, 04 Sep. NTP synchronization start
10:04:25, 04 Sep. CWMP: HDM socket closed successfully.
10:04:25, 04 Sep. CWMP: HDM socket opened successfully.
10:04:25, 04 Sep. CWMP: session completed successfully
10:04:24, 04 Sep. CWMP: Server URL: https://arcadyan.x.x; Connecting as user: ACS username
10:04:24, 04 Sep. CWMP: Session start now, server: https://arcadyan.x.x, Event code:
10:04:24, 04 Sep. CWMP: Initializing transaction for event code 2 PERIODIC
Skilled Contributor
Re: Cwmp
No.
Yesterday mornings logs , nothing to worry about!
Re: Cwmp
Nowt obvious! There's nowt about the BB connection at all, not surprisingly. It's all about your devices connecting to your LAN & talking to EE's TR-069 server.
Re: Cwmp
Still waiting for my fast path 😞
