by 1Bartman
Cutting out
My wifi has been cutting out for around a month
Can I cancel my contract?
Re: Cutting out
Is it the WiFi or is it the BB?
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
