by etsandy
New Member
Consistently Low (Capped??) Speed
Hello All,
After having a number of electrical faults in my home (All rectified now, thankfully!!) that had caused a number of restards on my VDSL modem/router(ASUS DSL-AC68U). The result of the restarts however is that it seems my line has been capped at the exchange, i beleive this as I had the connectiuon up for approx 30 days with <10 error on the downstream, my DR was 34999kbs at that point, I manualy reset the connection to see if it would change at all, to no avail with the connectiobn reseting back to 34999kbs. as you can see from the screenshot my thoerectical max is 78624kbs, however I typicaly got ~60000kbs.
My question is, how would I go around unlocking or removing the cap on the line? is it something I can do or would it require a engineer visit?
Many Thanks in advance!
Re: Consistently Low (Capped??) Speed
@etsandy   This will require an engineer visit as your not in control of the line speed to your premises. Your  in control after the router.
Are you on Fibre Plus?
What does BT Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number, use the Address Checker, not the Postcode Checker.
