by nv567 Investigator
Connection always dropping
For the past week the internet has been very intermittant. Weekend it has been on and off every 20 minutes. Would love if anyone had any ideas to fix it!! Tried different routers, wires, filters the lot! Thanks a lot.
DSL status: https://i.imgur.com/Clw1kVJ.png
Speedtest: https://www.thinkbroadband.com/speedtest/1517788610851366355
Exchange: https://availability.samknows.com/broadband/exchange/EABEC
Status log:
System Uptime is: 00:52:27
Current Time/Date is: 00:01:47 05 Feb
23:54:36, 04 Feb. Time is synced to NTP server
23:54:36, 04 Feb. Device connected: 192.168.1.246, 5c:f9:38:8e:d7:86, Bens-Air, lease time is 172800 seconds
23:54:22, 04 Feb. PPP connection up (ADSL)
23:54:21, 04 Feb. PPP: IPCP up
23:54:20, 04 Feb. PPP: CHAP authentication succeeded
23:54:19, 04 Feb. PPP: LCP up
23:54:16, 04 Feb. PPP: Starting PPP daemon
23:54:15, 04 Feb. WAN link up (ADSL)
23:54:13, 04 Feb. WAN link down (ADSL)
23:54:11, 04 Feb. PPP: Stopped PPP daemon(0,1,5)
23:54:04, 04 Feb. PPP: Starting PPP daemon
23:54:03, 04 Feb. PPP connection down (ADSL)
23:53:59, 04 Feb. PPP: Stopped PPP daemon(0,1,5)
23:53:53, 04 Feb. PPP: IPCP down
23:53:53, 04 Feb. PPP: LCP down
23:50:11, 04 Feb. Time is synced to NTP server
23:49:53, 04 Feb. PPP connection up (ADSL)
23:49:53, 04 Feb. PPP: IPCP up
23:49:52, 04 Feb. PPP: CHAP authentication succeeded
23:49:51, 04 Feb. PPP: LCP up
23:49:47, 04 Feb. PPP: Starting PPP daemon
23:49:46, 04 Feb. WAN link up (ADSL)
23:49:37, 04 Feb. WAN link down (ADSL)
23:49:35, 04 Feb. PPP: Stopped PPP daemon(0,1,5)
23:48:20, 04 Feb. PPP: Starting PPP daemon
23:48:19, 04 Feb. PPP connection down (ADSL)
23:48:15, 04 Feb. PPP: Stopped PPP daemon(0,1,5)
23:48:09, 04 Feb. PPP: IPCP down
23:48:09, 04 Feb. PPP: LCP down
23:47:33, 04 Feb. Device connected: 192.168.1.246, 5c:f9:38:8e:d7:86, Bens-Air, lease time is 172800 seconds
23:35:28, 04 Feb. Device connected: 192.168.1.126, 00:1a:79:32:5a:96, Unknown Device, lease time is 172800 seconds
23:32:32, 04 Feb. Device connected: 192.168.1.246, 5c:f9:38:8e:d7:86, Bens-Air, lease time is 172800 seconds
23:28:24, 04 Feb. Device connected: 192.168.1.150, ac:5f:3e:c9:ec:69, Samsung-Galaxy-S7, lease time is 172800 seconds
23:26:23, 04 Feb. Time is synced to NTP server
23:26:09, 04 Feb. PPP connection up (ADSL)
23:26:08, 04 Feb. PPP: IPCP up
23:26:07, 04 Feb. PPP: CHAP authentication succeeded
23:26:07, 04 Feb. PPP: LCP up
23:25:30, 04 Feb. PPP: LCP down
23:25:30, 04 Feb. PPP: LCP up
23:25:29, 04 Feb. PPP: Starting PPP daemon
23:25:28, 04 Feb. WAN link up (ADSL)
23:25:27, 04 Feb. WAN link down (ADSL)
23:25:26, 04 Feb. PPP connection down (ADSL)
23:25:16, 04 Feb. PPP: Stopped PPP daemon(0,1,5)
23:25:09, 04 Feb. PPP: IPCP down
23:25:09, 04 Feb. PPP: LCP down
23:19:28, 04 Feb. Device connected: 192.168.1.150, ac:5f:3e:c9:ec:69, Samsung-Galaxy-S7, lease time is 172800 seconds
23:18:48, 04 Feb. Time is synced to NTP server
23:18:45, 04 Feb. Device connected: 192.168.1.61, 84:38:38:f6:99:fe, android-ea0ffd00f851f0e6, lease time is 172800 seconds
23:18:32, 04 Feb. PPP connection up (ADSL)
23:18:31, 04 Feb. PPP: IPCP up
23:18:30, 04 Feb. PPP: CHAP authentication succeeded
23:18:29, 04 Feb. PPP: LCP up
23:15:09, 04 Feb. PPP: Starting PPP daemon
23:15:08, 04 Feb. WAN link up (ADSL)
23:14:59, 04 Feb. WAN link down (ADSL)
23:14:57, 04 Feb. PPP: Stopped PPP daemon(0,1,5)
23:11:31, 04 Feb. admin login success from 192.168.1.246
23:11:24, 04 Feb. Device connected: 192.168.1.246, 5c:f9:38:8e:d7:86, Bens-Air, lease time is 172800 seconds
23:11:21, 04 Feb. Device connected: 192.168.1.61, 84:38:38:f6:99:fe, android-ea0ffd00f851f0e6, lease time is 172800 seconds
23:10:53, 04 Feb. Device connected: 192.168.1.126, 00:1a:79:32:5a:96, Unknown Device, lease time is 172800 seconds
23:10:48, 04 Feb. System up, firmware version: v0.00.14.0001-OT (Wed Jun 24 19:52:22 2015)
23:10:31, 04 Feb. PPP: Starting PPP daemon
23:10:28, 04 Feb. WAN link up (ADSL)
23:09:46, 04 Feb. System start
9 REPLIES 9
Re: Connection always dropping
Reboot the router & try plugging it into the hidden test socket that is revealed when you remove the bottom half of the split faceplate (2 screws or press tabs) of your master socket. Only do this if you have a split faceplate. Do you have any extension sockets in the home even if unused? Are there any wires connected to back of faceplate of master socket?
Post the full router stats & System Uptime when plugged into test socket.
Is the issue any better?
Try the BT Quiet Line Test (dial 17070 Opt 2), preferably with a corded phone, in the test socket with the router disconnected. If there is any noise, report to your landline provider as a voice fault (don't mention Broadband). Often sorting out voice faults will fix the Broadband as well.
Thanks for the reply. I'll have to wait until tomorrow to try the test socket. For the moment though, I tried the quiet line on our phone (cordless). When the router is connected, there's a lot of noise and crackling on the phone when it's just on the tone, and also a lot of noise on the quiet line. However when the router is disconnected it's silent on the quiet line. No crackling at all.
Anything to read into that?
Thanks!
To clarify, I didn't turn the router off, I unplugged the router phone line from the microfilter.
Best test from the test socket.
Are there any phone extension sockets even if unused?
No others. Will try the test socket tomorrow. Thanks
Hi and welcome to the community, @nv567.
I see @XRaySpeX has given you some stellar advice and help here.
Let us know what happens with testing the socket.
Results
System Uptime is: 05:12:40
Quiet line is silent.
The internet light on the router is flashing orange.
While still in the test socket but with the router connected is the QLT still noisy?
Is the Internet light flashing orange continuously? It shouldn't be doing that. It should just be flashing green with traffic.
Yeah, with the router plugged in the quiet line is noisy.
