by jackryan1989 Investigator
Connecting my CCTV to My router
hey all in june this year i had an inco sky cctv dvr fitted along with two powerline adapters one at the router one with the dvr in anoth room all worked preety well up to recently i know have to reconnect it to the router every few housr at least thats if it will connect at all.
i have plenty of photos i have reset my router to factory setting and also the dvr please help me im really stuck and its the time of year i could do with it working.
many thanks
jack
12 REPLIES 12
Re: Connecting my CCTV to My router
Hi @jackryan1989
Welcome to the community. 🙂
Unless @XRaySpeX can impart some of his brilliant advice, I recommend speaking to our technical support team.
They'll do their best to help. 🙂
Let us know how you get on.
What exactly is the problem? Is it that you can't view it from time to time? Where are you trying to view it from?
You shouldn't ever need to factory reset the router except in extremis.
IMG_0406.JPGhi my problem began 3 weeks ish ago where the connection to the dvr drops totally and it take me man attemps to fix it.
i had it fitted 6 months ago and all was working fine the ethernets connected via x2 powerline adapters.
Yes, but disconnecting it from where? Where are you viewing it from?
hi pal its disconnecting from the router when i log in to 192.162.1.1 its not showing into logged in as a device also with it being offline i cant view it from my iphone as in the app it says its offline
The Brightbox's Currently Connected Devices isn't always accurate, so you can't go definitively by that.
Where are you when you try to view it on your mobile? In other words, are you away from home?
both at work and at home really as the cctv is fitted in the office upstairs, im currently connected to the 5ghz wifi and its still showing as offline
At home, when you are using your mobile to view, is the mobile connected to the mobile network or to WiFi on your LAN?
hi its connected to wifi of 4g
You mean it can happen on both WiFi & mobile data?
How/where are you seeing that the CCTV is offline?
yes i can not view the cctv via my phone on xmeye as the dvr device is showing offline when i check the dvr its dissconecting from the router and showig the message on the pic attachedIMG_0406.JPG
I still don't understand what is showing that error. Is it:
  1. A CCTV app on your mobile saying it can't see the CCTV?
  2. Or the CCTV itself thro' its management console?
If the former, it doesn't prove the the CCTV has discon'ed from the router as you keep saying but just that the mobile can't connect to it.
Please explain in more detail just what you are doing & and what is happening when you do so.
