by Pete51 Investigator
Connecting I-pad to printer
I have recently gone from Virgin to Ee and am unable to use my wireless printer from my I-pad or kindle it dosent seem to recognize there is a printer available
Solution
Re: Connecting I-pad to printer
@Pete51: Then it's not just a matter of getting the iPad connected to the printer but getting the printer connected to the router in the 1st place.
Have you followed Connect using WiFi protected setup (WPS) ?
If that doesn't work can you do it manually? Does the printer provide a list of WiFi networks it can see to which you can provide a WiFi password?
9 REPLIES 9
@Pete51  Have you reset this up on the printer so it connects to the router ? Have you reset this up the connection on your device to the printer ?
I have tried pressing the WPS button but nothing happens
Are you on EE for Broadband? What router have you?
Yes we are on EE broadband and bright box 2 wireless router
Can you see the printer from any other devices, like PCs? Do you see the printer in the Currently Connected Devices list of the router?
No we can't
Solution
Thank you very much problem sorted
Pete
Sent from my iPad
Thanks! You're welcome :)! Glad I could be of assistance & it is now sorted.
Was it WPS or manual?
How does the iPad see a networked printer on the LAN? Is there an app for it? What make is printer?
