by davpreec Established Contributor
Cant upgrade my fibre online
Hi my contract for standard fibre contract is up at the end of the month and i would like to upgrade to fibre plus but everytime i click to change my plan online it says it cant be done and to give EE a call. Cant i just upgrade my plan online without having to make a phone call?
Dave
Solution
Re: Cant upgrade my fibre online
You know that standard Fibre is capped at 40/10 Meg? So you won't gain any download speed from Fibre+ but will on the upload. That could be the reason EE won't upgrade you.
What does BT Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number, use the Address Checker, not the Postcode Checker.
13 REPLIES 13
What speed you getting from standard Fibre?
Around 30mb download and 10mb upload
Solution
Ok just checked it and it says downstream line rate 80 high 79 low downstream 20 high 19 low
Downstream handback threshold 75.9
And thanks for the replys
Also it says on the EE speed check that my recommended is fibre plus speeds but when i click to change my plan it always comes up with an error on the site and says to phone them. I dont know why
If that's the case you should be getting 40 Meg down now,
Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
Ok thanks for the help i just did a speed test posted results below
Can't see it. You need to give the full link of the results.
Better still try a wired speedtest, using an Ethernet cable supplied with the router, here http://www.thinkbroadband.com/speedtest.html . Click on the "Results Page" button at the bottom of the graph you first see and then copy to here just the "Link to this result:" link that you see below the next main graph.
Please also get the router stats I asked for earlier. They are what all line speed estimates are about, not speedtests.
Ok sorry my bad im using wired connection here is the results https://www.speedtest.net/result/8851570155
And https://www.thinkbroadband.com/speedtest/1576264353329511955
Edit - All sorted now just phoned and upgraded the guy i talked to was super helpful and nice. Thanks you can close this thread now 🙂
It's for you to close.
Glad this is all sorted @davpreec
Come back to the community anytime.
Leanne 🙂
No problem and thanks again all 🙂
Thanks! You're welcome 🙂 ! Glad I could be of assistance & it is now sorted.
