by dno101 Investigator
Can we use BB as a wireless Client Bridge?
Hi  -
I have BB2 set up for fibre broadband, and want to use my old BB as an on-site Client Bridge for my upstairs TV.  It is a smart TV and only has ethernet connection.  I have tried powerline adapters which drop connection very quickly in our house.  Is it possible to use the BB as a wireless Client Bridge (not a repeater or access point!).  Or do I have to buy an access point/bridge device?
thanks.
6 REPLIES 6
Re: Can we use BB as a wireless Client Bridge?
Hi @dno101,
Welcome to the EE Community.
If you search the Broadband forum there are a few threads which may help you with your query, including this one.
Please let us know if that helps.
@James_B: I don't know what a Client Bridge is but I think OP wants a wirelessly connected Ethernet hub. Most of the discussions on here are for an Ethernet connected wireless & Ethernet extender, such as How do I connect a second Bright Box 2 to a first BB2 in order to extend wifi.
thanks for the replies.  xrayspecs is spot on - looking to use the BB as a wireless ethernet hub so i can connect my TV to the BB2 network.  I have searched exhaustively about the internet, but all the guides use third party firmware with which the BB is not compatible.  Before i spend endless nights using the trial and error process, just wondered if it was actually possible.......?
Thanks.
Dunno if it'll work but you could follow some of the suggestions for setting up an Ethernet connected pair of routers. Once they are both set up remove the connecting Ethernet cable & operate the secondary over WiFi. By that time they will have consistent fixed IPs on the same subnet & so should operate in unison over WiFi.
thanks.  I'll give that a go - if anything, i'm persistent....what does confuse me though is the 'bridge mode' on the BB router.  what does it actually do, as it would seem to be the function i am after (although it didn't do the job, as the IP addresses, passwords etc all stayed the same - all it seemed to do was disable DHCP).
Well, with DHCP & NAT disabled it is just a bridge.
