by ohdaesu Investigator
Can't remove devices from smart hub
Not long had my smart hub and am having issues with my WD my cloud being seen by my Samsung TV.
If I restart the hub my TV sees it but if I turn the TV off and on again it won't see it.
When I check the devices on the hub its showing as connected, but there is also a WD mycloud home showing up in the list, but not connected, which I have unplugged as it had to be rma'd.
Is there a way to remove the disconnected drive from the device list as I'm not sure if I'm getting a conflict.
Any advice would be greatly appreciated
Solution
Re: Can't remove devices from smart hub
Yes, there's a Remove button on each item in the list of devices. Are you looking at it under Advanced Settings? Home things are pretty limited.
7 REPLIES 7
Hi @ohdaesu
Which my cloud you using? (I have a 3tb version). I also have a Samsung smart TV.
Have you checked that your Ethernet doesn't have a powersave option?
Solution
It's the mycloud, was working fine on my old net gear router and the mycloud home was working well using plex but it packed up after 3 weeks so have sent it back.
I've tried removing devices but there is no way to do it as far as I can see, looked everywhere including under advanced.
Just tried again but using a different browser, and now the remove buttons are there
Removed the cloud drive and now the TV can see it, thanks all for the advice
There must be a way. It's on my SH. Post an image of what you are looking at.
Thanks! You're welcome :)! Glad I could be of assistance & it is now sorted.
Thought it had solved the issue with the tv not seeing the drive but it's gone again, just set my tv to WiFi instead of having it on a cable and it sees it,
Very odd it keeps losing the drive when hard wired.
