by Orlandolovekill
Can't remember password for Livebox...
Trying to connect device. Can't remember password for Livebox. Tried entering WEP key, but no good.
Re: Can't remember password for Livebox...
The pwd should be on a label on the router or the KeepMe card that came with it.
You can login to your router at http://192.168.1.1 with username/pwd as "admin"/"admin". Then you can find your WiFi key by following Security / Wireless Connection /Security Key.
The pwd for connecting devices is the WEP key.
by Orlandolovekill
Thanks.
Yeah, tried the WEP key, but nope. Could be there's a zero that's a letter o (or vice versa).
That's always a possibility & similar; 1 for I, 2 for Z ...
by Orlandolovekill
Aye. Going to try a few combinations.
Thanks, again.
Copy & paste what you see in router to a Notepad. You should see it clearer.
