Highlighted
by Investigator
Can't get any devices to connect to the Internet following Smart Hub Upgrade
As a condition of my renewing my contract I stated that I wanted a Smart hub to replace my Brightbox 2.  The reason for this is that I am creating a Smart Home which has a couple of hubs and a Network Accessible Storage (NAS) so I wanted the 4 Gigabit connections provided by the Smarthub router.  Also I am just about to have Sky Q installed which has additional mini boxes which are connected via my home wifi network and the promised extra signal strength of the new Smarthub would be beneficial.  Bottom line is that the new Smarthub arrived yesterday and I connected it up using the new cables supplied.  The router powered up and displayed the blue lights i.e. indicating correct operation and internet connection.  The new router was visible to all my wifi connected device (Smart TV, Mobile Phone, PC etc.)  Problem was that every one of them reported that they were connected but there was no internet connection.  I rebooted the router but got the same results.  I Phoned EE technical who conducted an on-line check and concluded that BT would have to check out the line.  I reconnected my BB 2 and everything is back to normal.  My question is that if my BB and internet connection performs perfectly with the BB2 then why won't the Smarthub connect and what options are open to BT to 'Fix' this? I have a sneaky feeling that because I have not got the new router via a formal upgrade or new installation then perhaps there is something in the BB provisioning set-up that I have not received on my line but I'm not sure how credible this hunch is.  Any thoughts from the community would be gratefully received.
Highlighted
by Investigator
Solution
Re: Can't get any devices to connect to the Internet following Smart Hub Upgrade
Problem Solved!
Thanks to the suggestions from the responders I had the confidence to get back in touch with EE Technical and gave them the suggestion that maybe the new router had somehow been shipped to me without the normal admin processes activated.  I spoke to Daniel in their Plymouth support team who seemed to think this might be worth checking particularly since the serial number of my Smarthub could not be found on their system.  Long story short -- when the new routers are shipped as upgrades or to new customers then they are preconfigured with the customers log-in details but mine appears to have been taken from the warehouse and posted out to me without this set-up process.  Daniel talked me through setting the hub up through the hub manager screen and the bottom line is that the new hub is up and running and all seems to be working well.  Thanks to all especially Daniel.
6 REPLIES 6
Highlighted
@Barrowdad  Did you receive a activation data of your new hub ?
Highlighted
by Investigator
No I didn't receive anything new other than the Hub in the post.  This is probably because I was already on a Fibre Broadband package and was merely swapping over routers.  This is what I suspect may be at the heart of the problem but I would have expected EE Technical to have checked this when I called them rather than them raising the issue with BT.
Highlighted
Hi @Barrowdad
I would suggest giving our broadband team a call on 0800 079 8586 and asking them to get this looked into further.
Thanks, Leanne.
Highlighted
1. Post your full router stats.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
2. Post an image of the Advanced Settings/ My Network page.
There is no activation data issued for a router.
Highlighted
by Investigator
Solution
Problem Solved!
Highlighted
That is completely untrue. All EE routers come as default as being neutral to any user with the creds set as the vanilla readytoconnect@fs . To get it populated with your actual creds either:
  1. You set them yourself manually as you have done.
  2. EE has a remote config server containing all users' creds. When the router 1st connects to EE in its vanilla state it downloads your creds from that server after a few min. Now it may be that EE forgot to store your creds on that server; it has been known to happen occasionally.
Thanks! You're welcome :)! Glad I could be of assistance & it is now sorted.
