by Jlynch1994
Can my broadband setup be delivered rather than waiting a long while to get it ?
Was wondering if I could just have my broadband setup sent out right away rather than waiting on an engineer date ? I need it as soon as possible and 3 weeks is a long wait. Can they just not send it out and allow me to set it up? This is what usually happens it's plug and play simple enough.
Re: Can my broadband setup be delivered rather than waiting a long while to get
@Jlynch1994  Is your phone line already with EE ?
by Jlynch1994
No but there's an existing line already there. Does this matter? I thought all lines were compatible ? Thanks
Sent from my iPhone
Are you migrating like for like, i.e. ADSL to ADSL or VDSL to VDSL? If so, it should only take a few hours at most.
Who is your old ISP?
It's not a matter of just sending you anything. Wiring at exchange or cab. may need swapping around.
