by morgan72
New Member
Can anyone tell why I'm only getting 2.00Mbps download speed on my ee superfast
Re: Can anyone tell why I'm only getting 2.00Mbps download speed on my ee superf
Good Evening @morgan72.
How long has this been happening for?
Have you tried restarting your router?
Speak shortly,
Katie :)​​​​​​​
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
4. What does BT Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number, use the Address Checker, not the Postcode Checker.
