by spajones Investigator
Can I use a second brightbox 2 as a WiFi extender?
 Can I use a second Brightbox 2 as a WiFi extended to improve coverage in a WiFi black spot in my house?
Re: Can I use a second brightbox 2 as a WiFi extender?
Yes, have a read of To make a second Brightbox as a WAP on your LAN to the main Brightbox .
by Ace Contributor
Hello @spajones yes you can use almost any router as a Wi-Fi extender. Information on how to set this up can be found here:
https://lifehacker.com/how-to-extend-your-wi-fi-network-with-an-old-router-915783308
None of that article can be applied to a Brightbox, which is what the OP is about.
