by PaulRussell
New Member
Can I turn off the WiFi signal from my EE Router but keep the Lan?
My son has his A level exams coming up but I fear he is often using his smart phone when he should be revising. Can I turn off the WiFi signal from the Router but keep the Lan connection up and running? If this is possible access to the Internet would be restricted to the desk top computer which is connected via cable i.e. Lan.
Any help please.
Solution
Re: Can I turn off the WiFi signal from my EE Router but keep the Lan?
Yes, you may disable the WiFi by logging into the router & going to Basic Settings / Wireless Settings. If you have a Brightbox 2 you will need to disable both the 2.4 & 5 GHz bands.
For more sophisticated control you could use the Firewall's Access Control & Scheduling Rules to limit the times he may access the Net.
6 REPLIES 6
Yes you can disable the wifi on the router under settings. Only the wifi will be deactivated so the Ethernet port will still be active.
It maybe easer to take his smart phone off him?
Thanks,
Solution
EE Employee
Hi @PaulRussell and welcome to the community.
Hopefully, the advice above has helped with your query.
Many thanks,
Lee
by Mattglad
So with all of the solutions below they can be circumvented by the son resetting the brightbox to the factory settings. Is there a way to change the password on the brightbox on the factory reset so that I can retain the control?
EE Community Team
Hi @Mattglad,
There is a great thread by @XRaySpeX on changing your WiFi password with all the steps to change your password and also your admin password too.
Alex 🙂
@Mattglad : Yrs, just login to Brightbox, go to Advanced / System / Password Settings & change your admin pwd. Don't tell your son!.
Recent solutions
