by Becca199777 Investigator
Can I connect ee broadband to a sky q box
I have ee broadband and am thinking about getting sky q. Will my broadband connect to sky q. I already have sky in my home but want to upgrade but don’t want sky broadband??
by Ace Contributor
Solution
Re: Can I connect ee broadband to a sky q box
Hi @Becca199777 the bright box is EE's older router & the EE smart hub is the new router but they will both connect to a Sky Q box.
Thanks,
David.
11 REPLIES 11
by Ace Contributor
Hi @Becca199777
Welcome to the EE Community,
Your EE hub will connect to a Sky Q box for on demand services.
Thanks,
David.
Might sound a bit stupid but is and ee hub and brightbox the same thing
@Becca199777 :  No, they are both BB routers but the EE Smart Hub is the latest & the Brightbox is its predecessor from about 2 years ago.
by Ace Contributor
Solution
Thanks,
David.
Does it cost extra for the smart hub because I currently pay £35.50 a month?
It's not the cost; it's the product you're on. EE now gives the EE SH to new & upgrading customers on Fibre BB. Do you have standard ADSL BB or Fibre?.
Standard adsl
by Ace Contributor
@Becca199777 is fibre available in your area ? if it is you probably could get fibre for cheaper than your paying now.
Yes it is.
by Ace Contributor
@Becca199777  I would speak to EE about upgrading your service to fibre it would mean a new 18 month commitment but you would also be sent a new EE smart hub.
by foxijax Investigator
Hi   I've had Sky Q plus one mini box for a few years now, and I changed my bb to EE fibre with the Smart Hub a few days ago. I'm happy to report that everything works just fine. I used all the standard settings for both the EE hub and Sky Q. Happy days!
