Highlighted
Can I change my wifi password
Highlighted
Solution
Re: Can I change my wifi password
@Tr689 : Yes, for an EE Smart Hub follow Changing Your WiFi Password on a Smart Hub
Highlighted
Hi @jennaknight1987
On your router or your phone?
To both answer is yes, but in the case of your router, keep the original password safe in case you need to reset. (Take a photo and back it up)
Highlighted
Which router do you have? For a BrightBox follow Changing Your WiFi Password on a Brightbox .
Highlighted
Morning @jennaknight1987
Thanks for posting on the community,
Have you been able to change the password?
Speak soon 🙂
Highlighted
New Member
Can I change my WiFi password for my hub
Highlighted
Solution
