Highlighted
New Member
Call Fwd from a landline
I need to put a temporary call fwd in place as I don't have my mobile ...... can I put in call FWD to another mobile via a landline, or is there a support number I can call to do this ,,,,
Highlighted
by Ace Contributor
Re: Call Fwd from a landline
Hi @Tafflad
If you don't have access to whatever phone your SIM is in, then I'm afraid there's no way to set a divert, no.
If you've got a PIN on your answerphone, then you could dial into your voicemail from any other phone and set a recorded announcement asking callers to call another number.
Highlighted
@Tafflad : You need to have bought the Call Plus add-on for £5 pm to use Call Divert -see How do I use the features on my EE home phone?
If you are not talking about an EE landline then that landline provider should have similar chargeable features.
Recent solutions
