by Macey72
Broadband
Not getting very good speed. Connection keeps dropping while watching now TV or BBC iPlayer it freezes then picture is very blurry till connection speed gets better. Please help
Re: Broadband
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
