by SRG89
New Member
Broadband speed throttled to less than 1MB??
Hi Guys,
Seem to be having constant problems with our broadband speed being throttled by EE to less than 1MB.
It's not 24 hours a day but definately at peak times. Can't seem to easily speak to anyone at EE to sort out.
Had EE Broadband for around 2 months roughly.
Thanks in advance for your help.
Re: Broadband speed throttled to less than 1MB??
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
