by cochise007 Investigator
Broadband speed reducing
Over the last couple of weeks i have had a dropping data speed. I had a stable 70 Mbps with BT but a drop when i came over but i am running at 40Mbps 'ish. I play a game called World of Tanks and a specific add on that can create lots of errors that messes with interleaving. I have to run off the test socket as the socket was damaged when i moved in but not caused issues in the past. I prefer interleaving off if thats an option
Speed test today
https://www.thinkbroadband.com/speedtest/1506884475624253855
Exchange is LCCOP
DSL Driver VersionDSL Link Status DSL UptimeDSL modulationANNEX ModeCurrent ProfileTCM(Trellis Coded Modulation)
A2pvfbH043g.d26p
Link up
0 days 14 hours 54 minutes 31 seconds
VDSL2
ANNEX B
17a
ON
Line StatusDownstreamUpstreamSNRLine AttenuationPath ModeInterleave DepthData RateMAX RatePOWERCRC HEC ESINP
12.6 dB14.1 dB
18.1 dB0 dB
InterleavedInterleaved
44
43998 kbps11999 kbps
68953 kbps25079 kbps
13.1 dbm7.6 dbm
00
00
110
55.00 symbols56.00 symbols
Solution
Re: Broadband speed reducing
Had a change of master sockter and everything seemed to have settled, sync is 68Mbps at the moment after they reset. Before the socket change is was about 32Mbps. Thanks for everyone's contributions., really appreciate it.
16 REPLIES 16
DSL Link Status Link up
DSL Uptime 0 days 14 hours 56 minutes 24 seconds
DSL modulation VDSL2
ANNEX Mode ANNEX B
Current Profile 17a
TCM(Trellis Coded Modulation) ON
Line Status                      Downstream Upstream
SNR                                  12.6 dB         14.1 dB
Line Attenuation             18.1 dB         0 dB
Path Mode                        Interleaved Interleaved
Interleave Depth               4                  4
Data Rate                       43998 kbps 11999 kbps
MAX Rate                       68956 kbps 25082 kbps
POWER                          13.1 dbm        7.6 dbm
CRC                                  0                       0
HEC                                  0                       0
ES 11 0
INP                                  55.00 symbols 56.00 symbols
What does BT Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number, use the Address Checker, not the Postcode Checker.
Telephone Number on Exchange COPPULL is served by Cabinet 2
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Handback Threshold(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
WBC FTTC 18x2 Provide Availability
WBC FTTC 18x2 Sim Availability
Left in Jumper
  HighLowHighLow
Featured Products
Downstream Range(Mbps)
WBC FTTP Availability Date
ADSL Products
Availability Date
Left in Jumper
Other Offerings
Availability Date
Premise environment
Status
VDSL Range A (Clean)77.158.22016.551.2Available--------
VDSL Range B (Impacted)63.93519.38.530Available--------
FTTP on Demand33030--Available--------
WBC ADSL 2+Up to 16--14 to 18.5Available--------
WBC ADSL 2+ Annex MUp to 16Up to 1.514 to 18.5Available--------
ADSL MaxUp to 8--7 to 8Available--------
WBC Fixed Rate2----Available--------
VDSL Multicast------Available--------
ADSL Multicast------Available--------
Bridge TapU
VRIN
NTEFaceplateN
Last Test Date18-05-2017
Grr at formattingSmiley Happy
Don't worry about the formatting. We're used to it.
When you login to your Member's Centre @ https://web.orange.co.uk/r/login/ what does it say about Estimated Line Speeds under Your broadband speed ?
Yeah no worries. On BT has a very stable circa 70Mbps.
Estimated Fibre Download Speed is 59.1 Mb/Sec
Estimated Fibre Upload Speed is 16.9 Mb/Sec
Minimum Fibre Download Speed is 35.00 Mb/Sec
Maximum Fibre Download Speed is 77.30 Mb/Sec
Minimum Fibre Upload Speed is 8.9 Mb/Sec
Maximum Fibre Upload Speed is 20.0 Mb/Sec
Minimum Guaranteed Download Speed is 25.00 Mb/Sec
You should be getting at least 58 Meg sync speed.
Trouble is EE only guaranteed a Minimum Download Speed of 25 Meg when it should really be 51 Meg (which BT would have). A worthless guarantee not worth the chips its stored on.
Thanks for taking the time to help out XRaySpex especially on a Sunday night, i have been busy with work the last day or so and couldnt get back on the thread.
EE can sort this one, the only reason i have ever come across on this line not holding up at 70 meg in 3 years is because of a mod on World of Tanks called XVM that generates loads of errors through 15 minute games that screws with the software so it believes the line is unstable and drops the speed.
I had not used it in about 12 months and after using it again a month or so ago and the line speed starts dropping again. I am going to remove it but need a reset on the line stats (not sure the correct term?)
Need someone to facilitate this to pick this up.
Hi @cochise007,
If your DLM profile has been altered you'll need to get in touch with customer services to have it reset.
You should be syncing at least 58 Meg instead of the 44 Meg that you are. The reason you are not is that the DLM system has put you on a banded profile in response to past errors on your line, at the top of 1 of these Banded Profiles, altho' you now have no significant errors. You need to call EE to reset the DLM in order to remove any banding. However should significant errors persist the DLM will reapply banding.
by tdg Established Contributor
In my case I was told that they could not reset DLM and everything looked fine when the line was tested.  Unless a viable fault can be found and you are achieving at or above the minimum synch speeds then there is no fault.  If your cabinet is reaching full capacity then you are probably suffering from crosstalk and the BT wholsale line info is pointless.
Thanks for contributing and offering your experience with this @tdg
Let's see what @cochise007 comes back with.
Thank you
Richard
Solution
That's great to hear @cochise007
Have a good weekend. Smiley Happy
Thanks! You're welcome :)! Glad I could be of assistance & that you are getting the sync speeds your line is capable og.
