by SteveThePirate
Broadband speed is stupidly slow.. It has been "fixed" multiple times. What do?
I'm not the account holder just the user..
it started off with the internet going down to stupid speeds like actual **bleep**ing bytes not KB just bytes..
Technician came out and "fixed" it a couple times and its fine for about a week then it goes back to the same old **bleep** but now, i'ts worse.. the connection has become more unstable than my mental health at this point.
need a permanent solution please i've had enough..
Re: Broadband speed is stupidly slow.. It has been "fixed" multiple ti
1. Post your full router stats. For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page. Full router stats are key to any speed & connection issues.
2. Try a wired speedtest here http://www.thinkbroadband.com/speedtest.html and copy to here just the "Link to this result:" link.
by SteveThePirate
  1. Login to http://192.168.1.1 with the "admin" password written on the label on the router.
by SteveThePirate
STATUS
  Configured Current Line Status -- UP Link Type -- Interleaved Path Operation Mode Automatic G.992.5 (ADSL2+)
DATA RATE INFORMATION Upstream 888 (Kbps) Downstream 12650 (Kbps)
DEFECT/FAILURE INDICATION Operation Data Upstream Downstream Noise Margin 12.5 (dB) 6.1 (dB) Line Attenuation 17.9 (dB) 36.0 (dB)
Indicator Name Near End Indicator Far End Indicator Output Power 12.3 (dBm) 0.0 (dBm) Fast Path FEC Correction -- -- Interleaved Path FEC Correction 9588102 145519 Fast Path CRC Error -- -- Interleaved Path CRC Error 0 788588 Loss Of Signal Defect 2 0 Fast Path HEC Error STR -- -- Interleaved Path HEC Error 1861 642941 Error Seconds 15246 1052
STATISTICS Received Data 13985719 (Kbits) Transmitted Data 19366703 (Kbits)
Your BB speed is good but you could have a lotta errors on the line. What was the 'System Uptime' when you took those stats? Or do them again with the current 'System Uptime'.
Was the speedtest wired or wireless?
